Changing the grille
mikes10fx
Bronx, NY
2010 fx35 awd
Can i change the front grille on my 2010 fx without removing the bumper or do i have to drop the bumper to do so?
---------- Post added at 05:16 PM ---------- Previous post was at 04:59 PM ----------
i ask cause im getting a new grille and i am not good with working on my own car but would like to kno if its easy or not ?
I'll send you the instructions in a few. It's really really easy. I had to remove mine when I got the grille painted atte body shop.
---------- Post added at 06:42 PM ---------- Previous post was at 06:17 PM ----------
Here you go hope this helps:
Basically you just remove the air duct that sits above the coolant tank. To remove the air duct remove those four black plastic clips on the top then pull up. This gives you full access to the back of the grille to remove the 5 bolts and clip pawls. Be careful not to break any clips. Then gentley pull the grille out.
Thanks i am goin to try and give it a shot see if i could do it myself.
