Changing fog light and day light bulbs?
Hello to all FX lovers! Also to all Infiniti lovers !!
I just recently bought 04 fx35 and wanted to know which fog light and day light bulbs would be best for it? right now it has the regular ones but i want to get the white ones to match the head lights. Also the bulb that turns on right beside the headlight is also regular wanted to switch that as well. Any suggestions?
Thanks!!
Welcome to iS
You might wanna take a look at this thread:
2003 - 2008 FX Lighting Specs - InfinitiScene.com
Some people have switched to HID fogs.......to match the headlights.
For the DTRL a lot of us are using LED bulbs.
Quick answer... Hoen Xenonmatch fogs are the easiest to do and match very well to stock headlights, and LEDs in the DTRLs will do the trick. Just get "hyper white" or "super white" or whatever kind of white is being sold. A lesson learned on my behalf... you want a small # of LEDs in the DTRL. The more you get, the more angles these LEDs shoot out at, and the more angles they shoot out at, the more flooding you get. I personally don't like the look of the DTRL being "flooded" out, but rather a more direct beam of light. This is why I got 3-LED, where all 3 point directly forward so that it doesn't flood the entire housing with light and take away from the appearance of projectors or angel eyes or anything of the sort.
G'luck! Like others have said, check out the lighting discussions already posted!
Btw, quick reference on Hoen Xenonmatch, "white" LEDs in the DTRL and completely stock HID headlights:
Far left is mine, to the immediate right is completely stock... and the far right is Wireboltman's and he had the same setup as me. The weird fogs is wasabiz45 and his crazy creations :P
