can Maxima rims fit on FX ?
hangout
New York
Infiniti Q70L
Hi:
my friend want to give me a set of rims from his 2002 Maxima, tire size is 225/55/17..
I want to take the rims over and put the snow tires on it.. BUT do those rim fit on the FX good??
FX is a crossover vehicle, the sedan size parts should fit on it, right?
The rims likely won't be wide enough to mount a proper sized tire. I can't remember is the Maxima 17"s were 6.5 or 7" wide. Also, the offsets may not clear the FX brakes.
1st , isnt the Maxima FWD?! the offset will reflect that
2nd ... 17" really?! the smallest the FX came oem with are 18"
3rd agreed with JB , wont fit. But you can always try and let us know.
I would advise against it. Even if they do fit you will have issue with the speedometer being way off. The width will be probably be way to small not to mention the 17in size.
& they're freeeeeee!
---------- Post added at 03:59 PM ---------- Previous post was at 03:52 PM ----------
Winter or not still doesn't mean its less important to have the right wheel/tire combo on the FX. Not just visually but more for safety reasons especially so in the winter.
---------- Post added at 04:04 PM ---------- Previous post was at 04:03 PM ----------
Beefy tires there!
---------- Post added at 04:04 PM ---------- Previous post was at 04:04 PM ----------
Hopefully the offset will match.
Someone off this forum bought my OEM 20's and mounted them to his Maxima. Just haven't seen it the other way around.
