Calipers rear not OEM and experiences with the other brands
Case Holland
Netherlands Nieuw Beijerland
FX35 RWD Invidia exhaust
Case
Has anyone used/replaced calipers at the rear from other brands like Cardone, Centric.
So not OEM andso to say the cheaper parts if so what are your findings.
Is there trouble to expect by using other brands?
Case
I've used Centric on a previous car without issues. You would probably be fine with an aftermarket caliper. The worry of course is that it's cheaply made and the seals fail or something, but it's not likely. Most shops you take your car to outside of a dealer are likely to use aftermarket components. And FWIW, StopTech - the maker of very high end big brake kits and rotors - is actually a division of Centric.
I use and sell also aftermarket calipers for the rear brakes.
They work fine and sold many of them over the years and got no complaints so far.
If you live in Europe i can deliver rear calipers for 145-175 for a complete caliper with bracket and pins.
My email address is Effex35@gmail.com for questions
