Cabin Filter question
If you constantly use the a/c and do not circulate the system prior to shutting of the a/c than you will build up mildew in your a/c system from the continued dampness.
But you can try this. Turn on the a/c and set it for outside air and spray some Lysol anti-bacterial into the vents by the front windshield wipers.
Thanks Doc. I hope this works. :tup:
also you can open up the cabin filter compartment and spray it down with Lysol then wipe it down.
after all this you may still need to replace the filter one more time sue to the bacteria that is on there now.:alien:
