Bose pcb assy 100w -2db, tf
Ataher
Tripoli - Libya
My sub is out, I dismantled the unit and with some troubleshooting using a friend's unit I was able to confirm that the amp is busted, it has "BOSE PCB ASSY 100W -2DB, TF" written on it.
I would like to know if this amp repairable, or if it is being sold stand alone (not with the complete sub unit) somewhere, or if there is a proper aftermarket substitute for it - no worries about the space, I will figure something out.
Sent from my iPad
What was the symptom to your Bose amp? Hope that WiND DANCE DIY is the solution to your Bose amp problem.
Basically it does not work at all, I hooked a friend's unit (subs and amp) to my wiring and it worked, I hooked my two subs to my friend's amp and they worked, so I figured it is my amp.
I feel what you are saying, that my case is not necessarily the same as WiND's, but it is cheap and something I can try before I will be compelled to buy the whole unit for 250$ from the cars grave yard, they refused to sell the amp alone.
Sent from my iPad
do what i did.. bought an after market amp, and pac audio soem-t kit, amp wiring harness and wire in an aftermarket amp... under 100 and will sound better than stock
Sent from my iPad
Cool, be sure to report back and share what you found.
Could you send me some details or DIY on how you did that and where to purchase the parts to complete the job. I just want an upgraded amp then the original stock ones, it is not all that great to my ears....
Boss ce200m 200w monoblock amp on eBay..
PAC audio soem-t eBay
And 10ga amp install kit
And instructions are on here.. Plus I'm waiting for tchuck to post pics to me of how he set it up
Sorry man, I'm lagging. Its been pouring down rain here every day since you asked, but I'm going out to snap a couple pics right this second. Check your email in a few mins..
SfmDRuT2
Sure thing. Mbarb15 project will be my second step if this did not work.
I actually requested in another post if someone has upgraded the entire system as I was not very happy with it even before this amp quits on me, and jf2oo6 came back with a cool set up:
///341022
Jf2oo6 promised to post pictures and a DIY, if the financial time is right, I might as well go upgrading the whole thing.
Sent from my iPad
ok, here you guys go...
as per tchuck's diagram he emailed me.. i re-drew it and scanned it... (big thanks man)
///7480[/ATTACH]
here's another view of how u HAVE to wire your stock speakers to handle the impedance change
///7481[/ATTACH]
i will be posting a DIY addition or change with links and more info when i do mine this weekend..
got this 200w monoblock 2ohm stable amp on ebay for around $40
http://www.bossaudio.com/auto/200-watts-car-power-amplifier-mosfet-monoblock-chaos-epic-ce200m/
http://www.ebay.com/itm/Boss-Audio-...385?pt=LH_DefaultDomain_0&hash=item4d06e47971
you need to pic up this Pac Soem-T Line Out Converter... ebay for under $20
http://www.pac-audio.com/productDetails.aspx?ProductId=175&CategoryID=28
http://www.ebay.com/itm/SOEM-T-2CH-...Parts_Accessories&hash=item415b160c02&vxp=mtr
and also an 10 ga or 8 ga amp wiring kit... ebay for under $20
http://www.ebay.com/itm/NEW-BOSS-KI...udio_Video_Amplifier_Kits&hash=item416e4b08c2
http://www.ebay.com/itm/XAK-1700-10...udio_Video_Amplifier_Kits&hash=item53ed10f05a
http://www.ebay.com/itm/NEW-BOSS-KI...udio_Video_Amplifier_Kits&hash=item4166faf956
thanks and hope this helps
Guys, it worked!!!!
I just went to a local shop and picked a cheap 12V relay - less than a dollar, only I had to install it the opposite way via wiring so it is not directly mounted on the PCB, direct mounting did not work and I guess it is a circuit thing that is currently beyond my comprehension. I figured this out by coincidence while trying to troubleshoot why it did not work the first time. It can get messy and annoying when desoldering the original relay so get a vacuum hand pump, a word of advise is to try your new relay just by establishing contact before soldering it in place.
So I guess my case was an advanced stage of WiND's, it starts cutting till it completely quits.
Thank you all guys, I can now enjoy my subwoofer till the right time comes for an upgrade.
Sent from my iPad
///7480[/ATTACH]
///7481[/ATTACH]
http://www.ebay.com/itm/Boss-Audio-...pt=LH_DefaultDomain_0&hash=item4d06e47971
http://www.ebay.com/itm/SOEM-T-2CH-...cessories&hash=item415b160c02&vxp=mtr
http://www.ebay.com/itm/NEW-BOSS-KI..._Video_Amplifier_Kits&hash=item416e4b08c2
http://www.ebay.com/itm/XAK-1700-10..._Video_Amplifier_Kits&hash=item53ed10f05a
http://www.ebay.com/itm/NEW-BOSS-KI..._Video_Amplifier_Kits&hash=item4166faf956
Mbarb thanks for spending time on this, our prayers.
Sent from my iPad
Guys, it worked!!!!
Sent from my iPad
In case of some readers did not know what I meant by "opposite way", the relay can be directly mounted on the PCB but it will be on the wrong side of it which will not allow it to rest in the enclosure - it will be inappropriate too. So can you solder 5 x 2" long wires instead, and then cross the adjacent ones around and solder them to the relay, wrap it well with electrical tape to avoid any short circuits and lay it in place, you should be able to close the cover of the enclosure with a slight amount of pressure.
Sent from my iPad
