AWD Warning Light "ON" DTC Stored
  • Start date Start date
F
Fire0nic3
Guest
ITB10043
  • IF YOU CONFIRM An Applied Vehicle has the AWD warning light "ON" with one or both of the following DTC codes stored: - C1204 (AWD Solenoid) - C1205 (AWD Actuator Relay) ACTIONS 1. Replace the electric controlled coupling in the transfer assembly and the oil cover. NOTE: Do not replace the entire transfer assembly for this incident, should it occur. See this bulletin for further detail.
Just released
So looks like i am the first with this issue in the scrne
Should i take it to dlr? Or just change at local shop
---------- Post added at 04:53 PM ---------- Previous post was at 04:49 PM ----------
I have code c1205 act rly
