For the biggest brake system upgrade, Brake Pros offers world renown AP Racing 6-piston calipers running on 2-piece rotors. Each kit is designed to work with the original equipment master cylinder, ABS and traction control systems. Specially-designed 2-piece rotors are cross-drilled and slotted, the optimum for high-performance street, autocross and occasional track day use. Slotted-only versions are available for the serious track enthusiast. The curved vane construction provides maximum cooling, while significantly reducing unsprung weight.
DOT-compliant and TÜV-approved stainless steel lines are included to top off the upgrade and provide a huge improvement in pedal feel and stiffness. Brackets and hardware are made from aerospace-grade materials and high-strength fasteners. All AP Racing kits are complete with no other parts required. Install, bleed and go!
Many kits require 17" wheels or larger with sufficient spoke clearance. Download a brake profile template to check your wheels before ordering. Put decades of championship-winning experience on your car. It's not just for Formula One and NASCAR winners anymore. Or LeMans, or British Touring Cars, or WRC, or Grand Am, or Super GT, or DTM...
