Another Not sure if wheels will fit question...or what size tires to buy
WillsFX
Here are the wheels I want.
http://oewholesale.com/Clearance_2/20-Saleen-Wheel-Silver
I plan on painting them black. Not looking for anything too expensive because I will just be using these as a winter set.
Not sure if it fits. It seems other members here have 20x 10 wheels......but just want to be sure offset works out.
[TABLE="width: 100%"]
[TR]
[TD="bgcolor: #bec7ce"]WHEEL SIZE:[/TD]
[TD="bgcolor: #bec7ce"]20x10[/TD]
[/TR]
[TR]
[TD]WHEEL OFFSET:[/TD]
[TD]50[/TD]
[/TR]
[TR]
[TD="bgcolor: #bec7ce"]BOLT PATTERN:[/TD]
[TD="bgcolor: #bec7ce"]5-114.3[/TD]
[/TR]
[TR]
[TD]HUB SIZE:[/TD]
[TD]70.6[/TD]
[/TR]
[TR]
[TD="bgcolor: #bec7ce"]BACK SPACING:[/TD]
[TD="bgcolor: #bec7ce"]7.47[/TD]
[/TR]
[TR]
[TD]CENTER CAPS:[/TD]
[TD]Center cap included, Factory cap with 2.5” lens will interchange.[/TD]
[/TR]
[/TABLE]
If they fit, what size tires are appropriate?
Looks like some members use their oem 265/50/20 tires that came with their 20 x 8 wheels on their new 20 x 10 wheels. Didn't know tires could stretch that much?
Any help would be greatly appreciated. Thanks!
I wouldn't put 20's on 22's.
Most go with 265-40-22. With your rim setup, you'll be slightly tucked. 285-35-22 would give you more bulge, but less rim protection due to thinner sidewall.
TapaTalkin'
