AngryFx45 :: 2005 Infiniti fx45
Well its only been about a yr since the install and they still look good and new
Also i am a smoker so necessaryand i love the look on em
where did you mount jwt pop charger? mine is sitting loosely in my air intake box that's partially removed to install the pop charger. id like to fully remove the air intake box like you did but then my pop charger would just fall.. any tips?
If i remember correctly you have to
Remove all components... Even the plastics under the air filter unit.
Once thats done jwt comes with a metal bracket that holds the pop charger
But it might not sit correctly so what id done was i screwed it onto the the frame part of the car fisrt and grabbed the bracket and forced and bent it into a good position.... Where the pop charger would be sitting and screwed the pop charger last !
Hope it helps man ill try to see if i can find some pics for it ~~ but it should make sense ~
