Angel eye wiring instruction
digital_nrg
Boston
Hi gang, I bought a set of headlight with angel eyes already installed. However, all inverters are still in the plastic bag. I searched and couldn't find any specific instruction how to wire the angel eyes to the inverters. Also, from the inverter wire, should I connect it to the DTRL? I hope someone can help me with this. I'm not sure if what I asked making sense or should I take some pictures?
Thanks for any answer.
You can have the angel eyes be connected to your main Headlight's or the DTRL.
I suggest you connect them to the DTRL.
Basically...
Inverters should connect to Red (Power) and Black to the DTRL wire (Gray or Brown Wire)
There should be some wires(from the angel eyes) coming out of the headlights from the rear possibly through the black plastic. These wires connect to the inverter and the inverter connects to a +12V source (switched). You can usually zip tie the inverters to the headlight to clean things up.
Basically...
I took my FX 09 to have angel eyes installed. The lights look awesome, but is making the parking sensors go crazy when the lights are ON. Need help!!!! any thoughts?
