Renhalt
- Lexington, KY
- 2008 fx35
First off I admit I'm not the most knowledgable suspension guy so I need a little advice.
i have an 08 fx35 AWD, and I have all of the Gt spec braces and BC coilovers and right now running on my stock winter setup. when I did the coilover install I did not slam it and it still tracked straight and didn't pull either way so I have put off an alignment. Now that the ice and snow is here while driving it seems as if the rear end is not completely tracking as it should. While driving in a straight line in the snow it feels like the rearend is a little squirley. My question is this: I want to take it in for an alignment, but I don't know if I should go to the stealership or an independent shop to have the work done. I'm concerned that with the coilovers and such the stealership will not dial it in right or have the knowledge to make things right with the coilovers. Again, I'm no suspension guy and need help and or advise as to where to have the work done. Any help would be appreciated, thanks in advance!
