Aftermarket Pad and Rotor info for 06+
EG3
Premium Member
Premium
Boston, MA
This question has been asked several times so here's the types and the part numbers for some aftermarket brakes for 2006-2008 FXs:
Front rotor type: 42092
Front rotor size: 320mm x 34mm
Rear rotor type: 42078
Rear rotor size: 308mm x 16mm
Front Pad type: D888
Rear Pad type: D905
Both the rotors and pads for the fronts have changed with the 06 revision. Here are some common aftermarket brands' stock #s for these:
Hawk HPS Front: HB387F.547
Hawk HPS Rear: HB370F.559
Axxis Deluxe Fornt: 45-08880D
Axxis Deluxe Rear: 45-09050D
EBC Greenstuff Front: DP21671
EBC Greenstuff Rear: DP61666
Feel free to add.
Mods, maybe you can put this in a sticky..
Is there a similar set of info for pre '06 models?
When specifically did they brakes change?
I recently had my rears redone and they couldn't figure out what type of e-brake pad to use... (wife left brake on when driving).
STOPTECH website:
2006 Infiniti FX35
5 Record(s) found [TABLE="width: 87%"]
[TR="class: header"]
[TD]Part Description[/TD]
[TD]Flavor[/TD]
[TD]Notes[/TD]
[TD]Notes[/TD]
[TD]Position[/TD]
[TD]Part No.[/TD]
[TD]Fn[/TD]
[TD]Per Car Qty[/TD]
[TD]Pic[/TD]
[/TR]
[TR]
[TD]Brake Disc Hardware Kits[/TD]
[TD]Disc Brake Hardware[/TD]
[TD] [/TD]
[TD] [/TD]
[TD]Front[/TD]
[TD] 117.42051
[/TD]
[TD] [/TD]
[TD="align: center"]1[/TD]
[TD]
[/TD]
[/TR]
[TR="class: alternate"]
[TD] [/TD]
[TD] [/TD]
[TD]Rear[/TD]
[TD] 117.42038
[/TD]
[TD] [/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]Brake Pads[/TD]
[TD]Posi-Quiet Ceramic w/ Shims and Hardware[/TD]
[TD] [/TD]
[TD] [/TD]
[TD]Front[/TD]
[TD] 105.08881
[/TD]
[TD] [/TD]
[TD]
[/TD]
[/TR]
[TD]Brake Pads[/TD]
[TD] [/TD]
[TD] [/TD]
[TD]Rear[/TD]
[TD] 105.09051
[/TD]
[TD] [/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]Parking Brake Shoes[/TD]
[TD]Centric Premium Brake Shoe[/TD]
[TD] [/TD]
[TD] [/TD]
[TD]Rear PB[/TD]
[TD] 111.08670
[/TD]
[TD] [/TD]
[/TR]
[/TABLE]
105. brake pads are considered OE replacement pads.
