Adapter/space help!!!
Ontario/Inglewood, Cal
2005 FX35
Any idea???well im going with rim size 22x9.5 and size tire 285/40/22 not sure what size adapter/spacer(its the one that bolts up to the studs the the wheel) to go with so the wheel assembly seats flsh with the wheel well! Thanks! Will take pics
You would need to know what the offset on the rims are to know how thick of a spacer will be needed for a flush fit.
^yup, what he said. Each wheel is going to have an offset, basically, how much distance from the centerline of the wheel to the hub mount surface (where the wheel bolts up to the vehicle). Try this website to see it in action. http://www.rimsntires.com/specs.jsp
The OEM FX wheels are +50, I believe. I have 20mm spacers with OEM wheels. Essentially, I have a +30 offset. I'm sitting pretty close to flush, maybe another 5 or 10mm would be closer. So, get to about 20-25 net offset to be "flush." So, if you got wheels with +45 offset, you can get 20-25mm spacers to bring the wheel out and closer to flush. Does that make sense? Again, check the link to "see" it.
