WietseFX35
- Netherlands
- 2009 FX50S AWD
So today i checked the brake lines.
I have found some small damage to my left front brake line inside the wheel housing.
I managed to get a plier on it and sqeezed it back in place a bit, but i will change this line out when i have time.
Also i noticed that on the front left brake i installed the brake pads wrong.
On the pads there are small spring lips that should push the top part of the pads away from the rotor when the brake pedal is released.
These spring lips i installed on the bottom :eek.: but now that is also back to normal.
So hopefully that will help, my mechanic was busy today but i will get him to check the fault codes somewhere this week.
Hopefully the rotors stay straight:pray:
