A/C Temp control question
dingie888
Orange County
I search the forum but to no avail.
Hopefully someone could help. I was wondering is there a faster way of increasing/decreasing the temperature for the AC\heater control? Is there a faster way of going to maximum heat or maximum cool, or do you have to manually hit the up/down button until you reach the max cool/heat.
thanks...
thanks...
Mannualy :-(
can you use the voice command from bluetooth and say what temp. you want and fan speed you want? I haven't try my, so i don't know
If you like your car at lets say 68*..... press up and down on the temp control to 68*....then press auto. If you want it off, press off and the temp will be remebered so that the next time in the car, just press auto again and your set.
That's about as fast as you can get.
