F
Fire0nic3
Guest
ITB09041
- IF YOU CONFIRM A refrigerant leak at a refrigerant pipe/hose joint location, ACTIONS 1. Inspect the metal surfaces of the pipe/hose joint for damage or contamination. NOTE: Do not replace a refrigerant pipe, hose, or other A/C component if an o-ring seal will solve the leak incident, if it should occur. 2. If no damage is found to the joint metal surfaces, replace the O-ring seal. See this bulletin for further detail.
