91kord :: 2003 infiniti fx35
Those wheels are on par with GTRs as best looking setup on FX.... Good job
apexi ws2
Exhaust sounds a tad louder than stock, i had the tips extended using full polished stainless. The tig welding/parts alone cost me around $500ish plus the cost for exhaust ($900). I thought i overpaid for the welding.
Very "aggressive and sporty" looking. TIG welding service in nyc can run up to the same cost if lots of joints and elbows. Were they welding aluminum or stainless steel?
It has to be Stainless for sure. In BC its not hard to find welders to weld to stainless procedure because of our heavy industrial work up here.
I have countless friends who weld to PWP-10 which in BC is our Pressure welding procedure for Stainless steel pipe.
Depends on location, where I am, it probably would have been $200. But this would be at shops that fabricate all day. If it was a one off thing where the shop had to buy material, I could see $500. FWIW, TIG welding for exhaust tips seems like overkill since they're not stressed or pressurized in any way. But I'm sure the welds look great.
I do like the theme of your car overall and that you're using parts most aren't. And the wheels are ridiculous.
