Hey
i am replacing the bose amps and bose speakers in a 2008 fx45. using a rockford 5 channel amp with a dedicated subwoofer channel.
ive read through the "adding amp to existing bose sub" and ironchef's thread, along with the wiring diragrams, the FSM, and every other possible avenue, but have not seen an answer to this. if i did see it, my electrical/wiring knowledge is too limited to grasp it.
So the bose HU has 4 low level outputs to the main amp - its then bullshitted into six output channels (FF, FR, RR, RL, Center, Sub). I understand that a full range signal, which in this case is a summing of the RR and RL channels, is then sent from the bose speaker amp to the bose sub amp, where it hits a low pass filter, then to the sub.
So here is my question, and forgive me if this is stupid, but i couldnt figure out the answer.
I have 4 low level inputs to my 5 channel amp - obviously missing the input for the sub. how the **** do i combine create the input for the sub? is it as simple as using an RCA Y adapter for each the RL and RR inputs so i have 2 male RCA's for each?
