2nd Gen No TPMS Sensors
bobby2478
Minnesota
2010 FX35
I was wondering if anyone with a 2nd Gen FX that has aftermarket wheels decided to skip getting TPMS sensors? I'm curious what happens on the 2nd Gen when you run without TPMS sensors? If it's just a light that comes on sporadically, then it might be manageable to not have to buy extra sensors for aftermarket wheels and just go without them. But if there is a loud buzzing sound or other warnings that are always on, then it just might be too annoying to try and drive without sensors installed.
I realize on the 1st gen, the light only comes on after you run 35+ miles, and the light resets each time you start your car. So if you drive 35 miles or less one way, then you would likely never even see a warning light.
Does anyone know more about what to expect with no TPMS on the 2nd Gen? Thanks!
I'm running the summer setup without TPMS since i've bought the car 2 years ago with no problems. No buzz, no sound. Just like the seatbelt sensor (at least on the 09 models). The light is not annoying or anything it's just...there.:tongue (2):
Ok, thanks! Do you have the Nav system too? I'm wondering if there is anything else that happens with the Nav system since you also can see the tire pressures there via settings.
Anyone with a 10+ 2nd Gen FX experience anything different?
I also do not run the sensors in my summer wheels. Only the light comes on, and stays on when the vehicle is running.
No problem, never bothers me at all. I also have Nav.
On the Nav display you will see 3 stars like this ***. It will not say anything only it won't read your tire pressure.
+1
I have them reprogrammed twice a year (winter/summer).
Well I was looking to avoid the extra hassle of having to get my sensors removed from my stock wheels and put onto my summer aftermarket wheels for a few months, then having to pay to have them put back on my stock wheels again for summer.
I was also looking to avoid having to pay $200 or more for sensors for the aftermarket wheels, since they will be only used in the summer.
So if you want to make use of the TPMS function with aftermarket wheels while also using your stock wheels in another season, you only have 2 options: you can either swap your stock sensors back and forth between summer and winter wheels, or you can pay to have extra sensors for the aftermarket wheels.
Or, if you're willing to put up with a minor inconvenience of having a light on your display lit up, then you don't need to pay anything. Also, another thing to consider is using nitrogen in your tires instead of air. Since I've been having nitrogen used in all my tires I simply don't see any fluctuation in tire pressure, either in winter or summer months. With regular air, I had the tire pressure warning come on due to low pressure when the temp dropped.
While I am forgoing a feature of my vehicle by not having pressure sensors for part of the year, it's definitely not a feature that's worth $200+ to me to make use of in the summer.
Right around $200 -- http://www.tpmsoutlet.com/osc-8204.aspx
Your points are well taken. To me it's not an annoyance of a light on the dash that warrants me to do this, but the safety value in it.
You'll obviously know if you have a tire blow out, but a slow leak is harder to detect e.g. nail in tire. I check my tire pressure almost every time when I drive via the screen, there is no chance I would check it manually that frequently.
Nitrogen cost $$ (anywhere from $5-$25/tire) and air is still free at some gas stations, if not, $.50 or so.
Swapping sensors just puts unnecessary wear on a tire and wheel so that wasn't an option for me.
In your scenario based on your priorities, nitrogen sounds like the best bet.
Bobby, I think the same way as you. I drove for over 30 years with no tire pressure sensors with no problem and see no reason to waste my extra dollar for my summer rims.
An extra cost you forgot was reprogramming the sensors each spring and fall. My Dealer charges $45 each time, so add that onto your $200 for another set of sensors
Yeah there is a minor safety risk by not having sensors, so it's whether you're willing to accept that additional risk or not. For me (at least for the short term), it's an extra risk I am willing to take. Swapping sensors isn't very feasible either really, which means that your only options are to skip sensors all together or pay $200 for extra ones. While it's not a huge cost, since I'll already be paying $3k on rims and tires, not to mention all the other things I need to pay for this summer, an extra $200 right now just insn't in the cards. Down the road in a couple years maybe, but just not right now.
I think it depends on where you're from as to what cost nitrogen is. My dealer puts nitrogen in all my tires and never charges me anything. Plus, since it is so mainstream now, many tire service places have the equipment as well. So there may be some cost depending on where you live and who does it.
But I can personally vouch for the difference. With regular air, my pressure was always fluctuating, especially when the temperature changed from cold to hot, etc. Pressure would always inevitably get low, and you'd have to top them off. Another factor to this is whether the station where you get air at filters out all the moisture from the compressed air. Since having nitrogen however, I can go all year without having to adjust my tire pressure, as I don't see the pressure drop and require me to top it off. Unless you have tire damage from a nail or puncture, the pressure stays very constant and doesn't fluctuate like it does with compressed air.
---------- Post added at 05:26 PM ---------- Previous post was at 05:16 PM ----------
Very good point about the extra cost for getting them reprogrammed also. Like you, I also drove for about 20 years with no major problems (i.e. no flat tires, although I've had a few punctures before). The one big risk I do see isn't necessarily from a safety standpoint, but from a rim damage standpoint. If you are running low profile tires with big wheels, you have less room for error. So low tire pressure can lead to damaging your wheels when you hit a bump, pothole, etc. In this case, $200 would be way less then it would cost me to replace a $500 wheel if it gets damaged.
This is the main reason (at least to me) where it would possibly warrant the sensors, if nothing else to protect your investment (my aftermarkets will cost be almost $2k just for the wheels).
good points, to me, if i buy set of wheels, it will be for the whole year, won't have any summer/winter wheels. just one set.
so i guess using the original TPMS on the new wheels is my best bet, but do they actually work on any wheel? that's the key for me i need to find out, unless it's been answered:confused.:
As long as the wheel you purchase is tpms compatible, then yes, your oem tpms will work.
