275/45/20 To cut or not to cut springs???
zx12rtoo
Northern VA
2013 s4
Bout to put on H&Rs currently running 265/50/20. Like the idea of the 20" stockers looking bigger with 275/45 but don't want to cancel the drop. thinking if I cut 1/2" front shave 1/2" rear should be decent. Checked forums did not see exact answer. Can anyone comment on the 275/45 cut H&R ride?? SHould I be good with 20mm spacers on either setup if I sticket with 265/50 cut? According to this chart U loose almost a full inch.
http://www.sstire.com/index.php?option=com_content&task=view&id=3&Itemid=17
using the tire calculator in the "members" tab above....
the 275 45 20 tire will be .3 in SMALLER in radius (2x is the diameter :wink:), so its going to make a little difference. I think there is a few people with cut H&Rs, I think you will be good... and great with spacers.
dont forget the diff in size will change your odometer speed and the MPG reading on the onboard computer.
