20mm spacers rear hub removal?
infinitifan25
wichita
its been awhile since I had my rotors off in the back. but to double check my memory, in order to change out the studs that came with my 20mm spacers ill have to take my rear hub off right? Im planning on jacking everything up today and getting the fenders trimmed and maybe tomorrow putting the spacers on. it just sucks taking them off and am hoping I dont have to :tdown: I will post pictures when im done though. BTW got a few new things ill take pictures of to i did over the weekend:tup:
you only have to remove the calipers and rotors, you can knock the studs out after
here is a front diy -> ///91
pretty similar procedure.....
OKay man thanks alot. I pulled the caliper and rotor off and yes your right. you dont need to take them off. bad news is i bought the 20mm spacers from b2 auto designs and the lugs are to small for the hole. so now i have to buy some 50mm studs that have a bigger diameter for the hub. :(
