2013 Infiniti JX35: Vibration When Making Low Speed Turns
Summary of ITB12072:
IF YOU CONFIRM There is a vibration or judder feeling from the rear of the vehicle when making turns on dry roads at low speeds (under 40 MPH), and it does not occur if the Electric Controlled Coupling is electrically disconnected. ACTION Replace the Electric Controlled Coupling in the transfer case assembly for the rear final drive. See this bulletin for further detail.
Geez seems like there is a lot of issues with the JX
How about during heaving stop and go traffic on the freeway. Where you depress on the accelerator pedal, let go, and depress the accelerator again. (All at low speeds under 25mph.) And at that time the car will shake bad. Feels like the transmission was slipping really bad. Or how my wife said "felt like the engine was going to fall out." Can this be applied as well since it did not happen while turning?
