2011 QX56 All Terrain Tire
Sitti
CA
Hello
I have 2011 QX56 4WD with 22" tire. I am thinking about change my tire to all-terrain tire. I am new at this and have no idea how to choose tire:embarrassed: Can you guys help me? I am thinking about getting 18" or 20" rim for more off-road capable and comfortable ride. OEM tire size is 275/50-22. If I go for 18" or 20", what size I should get so I don't screw up QX56's ground clearance and performance?
Thank you very much for your help:smile (2):
Just make sure the outer diameter stays the same. If you look at the tire specs it will tell you, then you can find a compatible size for smaller wheels.
Check Nitto Terra Grappler All Terrain tires or Pirelli Scorpion ATR tires.
I have it in 285/50/22 on my truck.
Also, Check ClubArmada.com (Armada and QX56 forum)
