2009 FX37S AWD Differential Fluid.
Ryuzaki
2009 FX 37S
Hello, I am new here. Not gonna lie that I came here because I can't seem to find a definitive answer on what fluid and how much should go into the front and back differentials. Some sites say it needs 75W90, some 80W90, some mention that you need OEM oils, different say that synthetic is an okay replacement. Can someone tell me once and for all which oil to which diff and how much of it? Thanks.
EDIT:
When it comes to the car itself it has an FX37S badge on the trunk doors, but once I've been ordering some parts with a local supplier and after telling them the VIN they insisted it is QX70, not FX37 - I don't know what the difference is but it could be that it was one of the lasts FX37s on the line before they started putting QX70 badge on it. I'm saying this in case this changes anything with the differential oils and quantities.
Straight out of the owners manual. Even though it says to use 80W90, I used 75W90 because that is all that I could find that was GL5.
