2009 FX35/FX50 BCM and Around View Camera Monitor Not Working Due to Water Leak
ITB08050:
IF YOU CONFIRM The BCM (Body Control Module) is not working correctly (power windows inoperative, power door locks inoperative, etc), and/or the display for outside cameras (Around View Monitor or Rear Camera) is not working correctly (gray blocks on the screen, steering grid lines do not move, upside down image, etc), and the driver side floor pan is wet (wet floor underneath the carpet or underneath the rubber mat on the engine wall). ACTIONS 1. Find the source of the water leak (see Service Procedure) 2. Use 3M Fast 'n Firm Seam Sealer-or equivalent-to seal water leak(s). 3. Allow the sealer to cure, and then recheck for leaks. 4. Replace the BCM and/or the Around View Monitor Control Unit / Rear Camera Control Unit. See this bulletin for further detail.
