2009-2012 FX35 Hesitation/Stops Running at Idle/Low S
ITB11018:
IF YOU CONFIRM The customer reports any of the following: Engine hesitation at idle or very low speeds, and/or Engine speed drops lower than expected when decelerating or coming to a stop, and/or Engine stops running at idle or very low vehicle speeds (parking lot maneuvers), but can be restarted. NOTE: this incident may occur immediately after an oil change. ACTIONS 1. Refer to Step 2 in the Service Procedure to confirm this bulletin applies to the vehicle you are working on. 2. If this bulletin applies, reprogram the ECM. See this bulletin for further detail.
I just had this done. The car still hesitates to small degree during "parking lot" type driving. Anyone have the same reprogram issues?
I did the trans TSB update and had the dealer clean the throttle bodies at the same time. The hesitation was there for a while but slowly happened less since only using Shell premium gas for a few months.
