Please use these points with extreme caution, never get under a car unless you are 150% sure it is safe and all your equipment is in superb condition. DO NOT GET UNDER ANY CAR WITHOUT USING JACK STANDS!!! I do not take any responsibility from these instructions, so please use them with caution.
Front:
When lifting from the front of the vehicle make sure the emergency brake is on and that the rear wheels are chocked.
Using the factory scissor jack.
Pinch Welds
(Notice the location)
Using a hydraulic floor jack.
Do not use a hydraulic floor jack on the pinch welds unless you have a pinch weld attachment.
View attachment 48 View attachment 49
Hydraulic Jack point front (location #3 in the diagram below).
Picture below of #3 above:
Jack Stand Possible Locations:
Frame Rail
Rear:
When lifting from the rear make sure the front tires are chocked and the car is in park.
(I don't have this section done yet.)
If anybody finds this information incorrect please help me correct it. If you have pictures to add please post up. Thanks.
Front:
Pinch Welds
Frame Rail
Rear:
