TOOLS:
T30 TORX SCREWDRIVER
FLATHEAD SCREWDRIVER
SUPPLIES:
REAR ESCUTCHEON COVER -> http://www.infinitipartsusa.com/par...5555&callout=4&catalogid=2&displayCatalogid=0
PART #4
PROCEDURE:
- THIS IS WHAT THE STOCK FRONT DRIVERS KEYHOLE LOOKS LIKE (WE ARE GOING TO HIDE THE KEYHOLE).
- OPEN YOUR DRIVERS DOOR AND REMOVE THIS PLASTIC COVER, COVERING THE TORX SCREW.
- INSIDE YOU ARE GOING TO UNSCREW THE TORX SCREW WITH YOUR T30 TORX. THE SCREW IS HELD IN PLACE WITH SOME KIND OF PLASTIC RETAINER, SO DON'T WORRY ABOUT IT FALLING.
- ONCE THE SCREW IS FULLY LOOSE, YOU CAN GRAB THE KEYHOLE AND COVER AND PULL IT OUT. YOU ARE GOING TO PRY OFF THE COVER WITH YOUR FLAT HEAD SCREWDRIVER (AT THE LOCATION SHOWN BELOW).
- COVER REMOVED.
- COMPARISON OF THE REAR AND FRONT ESCUTCHEON.
- NEXT, TAKE THE REAR ESCUTCHEON COVER AND SLIDE IT INTO PLACE AT LOCATION 1.... AND SNAP IT INTO PLACE AT LOCATION 2. (WHEN YOU ORDER A NEW REAR ESCUTCHEON, YOU WILL HAVE TO REMOVE THE COVER FROM THE MOUNT FIRST). REMEMBER, THE KEYHOLE IS NOW HIDDEN UNDER THE REAR ESCUTCHEON COVER.
- SCREW BACK THE T30 TORX.
- PUT THE PLASTIC TORX COVER BACK ON.
- DONE!!!
***YOU NOW HAVE A HIDDEN KEYHOLE, ALWAYS MAKE SURE YOUR FOB BATTERY IS FRESH BECAUSE YOU DON'T WANT TO GET STUCK OUT OF YOUR CAR IF THE FOB DIES. ***
SUPPLIES:
PART #4
PROCEDURE:
- COVER REMOVED.
- DONE!!!
