2004 FX35 Few Questions ?
insane87
Lebanon
Okay here are my problems and questions :
1- I bought 2004 fx35 and I only have a normal key, Can I request remote smart/intelligent key? and how much would it cost ?
2- When I open the car with the key it only opens driver side door , How can it open all doors ?
3- The electric lock only works for 3 doors how can I let it work for 4 doors,should I fix or there is certain button or lock ?
4- The key can only close front windows, should it close the back too ?
The problem is I always have to check if all doors are locked :( ! Any solution ?
I'm got a intell key for my FX.. It cost $160.00 programmed. I think it all depends on the dealer you go to.
1) You can get the ikey from the dealer, but you have to have the tech package to work. Also, a dealer will have remote start option to install, or you can go aftermarket which would probably be cheaper.
2) Turning the key once opens one door, if you do it twice in a row it unlocks all doors
3) 3 Doors only lock/unlock? Sounds like one of your actuators doesn't work. Very common problem on the Infiniti G35 and FX's. Actuator is $175 for the part. You can do it yourself in about 1-2 hours depending on the door, and how handy you are at fixing stuff. My rear pass went out and it took me 45 minutes to replace, and that was taking my time....OR approx a $500 fix at the dealership including the part.
4) 2 front windows is correct....only the FX45 can open/close all 4 windows. Doesn't make sense why they did it this way with the FX35...but that's the way it is.
Back to my topic :
1- I found this item on ebay, does it work for my car ?
http://cgi.ebay.com/ebaymotors/New-...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
2- Can I let the satellite radio work in my car ? I have the sat button in my radio but it doesn't work ? What should I buy/do ?
1.No.
you dont have a Smart key now right? anyways the correct smart key has 3 buttons. you must have a smart key to use this. a smart key is one that does not need to be inserted into car
2. you may need a Sirus/XM module to get that to work. also you will need a subscribtion from XM or Sirus
1.No.
I have normal infiniti key with no buttons, but it has a small hardware part where they say the key wont work if this part is removed.
Explain what you mean by "small hardware part" - there are two types of keying systems-
normal key fob remote unlock/lock
or
I-key which allows you to start the car w/o key in ignition
he is refering to the small chip in the key that if not present it will not start the car. ie. you can get a key cut at a hardware store it will open your doors and trunk but will not start the car.
The first link is intelligent key true ?
Also for sale here : http://infiniti.sewellparts.com/accessories-catalog/Keys/FX-2004-336.html
Anyway how does it work? How can I install the intelligent key?
