- 2017 QX70S
- Name
- Andy
Looking for the "third" fuse box for the +09 FX?
Remove the battery compartment cover and crowl top cover to access the IPDM.
IPDM
Lay some rag over the batter terminals so that your IPDM cover won’t be all scratched up and to protect the wires from sharp edges on the battery terminals.
Remove the IPDM, reach behind the IPDM and squeeze the two tabs toward the front of the car and lift it from the bracket.
Remove the IPDM cover, use a small flat head screwdriver and lightly pry the tabs up while you pull the cover away from it.
Remove the IPDM from it backing bracket, carefully work the wire bundle out of the guide tabs at the bottom of the backing bracket. Spread the two tabs on top of the backing bracket and then pull up to take the IPDM internal off the backing bracket.
IPDM
