06 thru 08 HKS legamax
wiseguywm
Norristown PA
can anyone tell me if a full cat-back exhaust is offered by HKS? I think I made my decision on the exhaust I want to buy only to find out they only offer the rear section. HKS website has a full cat for the 03 thru 05. I see no benifit in rear section only. what should I do? :mad:
Go on ebay and by the Ztek Stainless Steel Midpipe only. It will mate right up to the HKS or stock rear section. Trust me I know. Great quality too...only other option is custom since the HKS exhaust for our ride has been discontinued.
Ztek is very questionable. I'd stay away. HKS mid might be a special order from Japan last I checked. But that was a while ago
HKS mid-pipe is same diameter as OEM, cheap fix is remove the resonator and put in a high flow resonator. If you have a FX45, no resonator is needed but you will get drone in a FX35.
Also, Y-pipe is the key here, Ztek might be your only option, I don't think it's a huge risk trying it out. I would.
Apologies for resurrecting an old thread, but after a lot of searching I still haven't found my answer...
Does anyone know whether or not the 03-05 catback (midpipe and rear) will fit on an 08 FX35? If not, why?
Also, I have found the rear section only (p/n 34005-BN002), but it always states 03-06. Can anyone confirm this will indeed work on an 08? There is nothing listed specific to the 08 on the HKS website.
Thanks in advance for any help you guys can provide!
Also, in case anyone is interested, FWIW I came across the shutokoengineering website (can't post links) which seems to have some pretty good prices on HKS, and they appear to sell the midpipe separately (which I saw some people interested in while searching through the threads)
It will fit 2003-2008. From what I understand, HKS only posted years they tested it on.
