06 M45 w/JL Audio CleanSweep
06finSport
SC
I'm new here but I'm trying to get straight to it. I have an 06 Infiniti m45 with both JL audio CleanSweep CLSSI and the CL441dsp. My only issue with this is that I can't seem to figure out how to put an aux input (3.5mm headphone jack) in and have it play through the system. How can this be rectified? I know the CL4411dsp has something on it that says aux input but how do I make it work? There are rca's plugged into it, and I found that they ended up under the cupholder in my car, I plugged a rca to 3.5mm jack to it but I just can't seem to figure out how to get it to play through the factory system. Any help will be GREATLY appreciated.
God Bless
If it's anything like other after market systems, you need to have an XM-capable (not equipped) radio. If so, try hitting the radio button on the dash multiple times until it goes into "XM" mode...then mess with the presets, etc.
(this is based on how the USA Spec. PA15-INFI and PA15-NIS devices work)
