03-05 Fog Light Housing Part Number and Cost
drew855
NJ
Sorry to create a thread for such a minor question but I could not find the answer anywhere on the site. Can someone please tell me the part number and the cost of a fog light housing for an 03-05. Thank you.
Thank you. Did you replace the housing yourself. How involved is it/what is required to remove the old housing.
You will need to drop the lower front bumper shields to allow access to the fogs. you will need a socket set, phillips screw driver and a push pin removal tool, you can use a flat head instead but be careful not to brake the heads off the push pins. After you remove the lower shields use a flash light to see what your doing, should be pretty straight forward, maybe an Hour or less.
I actually took off my front bumper. With jack stands you would be able to do it without taking if the bumper. There is one bolt on top of the housing holding it in along with some clips. The bolt on the back of the housing, center, is the level adjustment. Very easy diy, probably 30 minutes .
Thank you both for your replies. There is actually more to this story which I will share when it is resolved (or IF it is resolved).
When I first did my fog lights, I was a noob.
Although, I was a noob, this DIY was pretty easy.. I didn't removed the whole bumper. I just removed the splash guard, it takes <30 minutes to replace both lights. Passenger side takes 15 min, Driver side <15 min.
Here's my first thread ever...and it's about the subject:
https://www.infinitiscene.com/search/1/?q=11983-New-Fog-Light-for-my-2006-FX35
