Blows HOT air set at 62degs. Help!
akachi
NY Queens
2011 FX35 AWD
Matt
Hey guys, I just noticed this winter that when I had the temperature set at 62 degrees, it blows hot air. I thought it may be because it's really cold outside during winter (around 20-30 degs) but I've tested again when outside temperature was 75+. It seems that any temperature I set after 62, it blow the same hot temp. So it's either very cold AC at 60-61 degrees, or hot heat from 62+.
Can you guys check your car if it does the same thing? and if doesn't, will the warranty cover it?
Did you have the dash apart for any reason? Sometimes the internal thermostat isn't plugged back in and the auto HVAC only blows hot air.
I had auto start installed during that time.. I guess I will check on that
---------- Post added at 09:51 PM ---------- Previous post was at 09:13 PM ----------
Yup. The guy who installed my autostart forgot to plug it back in. Lol thanks
this happened to me and it was a loose cable from the console control unit. Since infiniti replaced the control system unit since the control lighting werent working.
Bring this back from the dead. Any more information on what plug or wires to look for? My 2013 fx does the same thing and blows hot air at 62 degrees even with the ac button on.
I pulled the dash open the other day and that was my problem. I plug was not connected. Now everything is back to normal with no codes. Thanks everyone.
