tranceduden
- Canada
Sooooooo I Installed Slim Ballast HID Fog light kit from DDM today on my new 2012 FX , exact same kit I previously got for my 2010... Install was easy, got it done in under 1 hour, both lights tested great separately and then together. Put everything back, turned the car on multiple times to make sure they come on (they are DTRL's in Canada) , worked great.
Then turned on the headlights + fogs, worked great, about 5th time I turned the fogs off and on, they stopped working. The fog light indicator on the dash shows they are on , but they are not.
If I recall, one member had a similar issue I wonder if they resolved it ? Is there some fog light fuse that could have burned out ? (Overload ?) I am really disappointed, I am pretty sure the kit is ok, it must be something else that's causing the fogs not to turn on. Any suggestions would be appreciated.
:at-wits-end:
:at-wits-end:
