Fire0nic3FX
I notice mine will cold start around 1700-1800 RPM on a warm day after sitting overnight. But if it's below 40 outside it cold starts around 2100 RPM. Seems pretty normal due to the cold weather.....
Hey no problem brotha!
I guess we can make a note that the FX50 throttle body is a socket bolt instead of an allen bolt. FX35 is an allen bolt though.
Good job man!:top:
---------- Post added at 10:12 PM ---------- Previous post was at 07:23 PM ----------
By the way you should of taken some pics for us to see how dirty they were. I recommend cleaning them every 10-15K miles or whenever you change the air filters just for the hell of it. :smile (2):
so looks like removing the negative battery, you can move the butterfly with your fingers as much as need to get it perfectly squeaky clean!)
I need to do this really soon.. Just debating on the butterfly... To touch or not to touch, that is the question.
TapaTalkin'
TapaTalkin'
Nice Aaron. I hope pulling the negative is enough to avoid issues. Did you lose the presets?
TapaTalkin'
Nice job. The black stuff on both sides of your TB is probably residual oil from when you had the K&N air filters installed. :p
