I am not quiet sure exactly what the problem or concern would be ...
The concern in general that you've probably heard is for the predictability of your braking system. The oem system is designed to account for weight transfer and does so mostly by staggering the rotor/caliper sizes front to rear. To upgrade one end and not the other is to distort this factory setting and CAN in effect "de-tune" the system as a whole by, among other things, increasing stopping distances. It's not always true though, and it looks like it isn't anything to worry about in this case.
I'm sorry for the noob question but i don't understand if these will work on the FX35 rotors or if you have to buy the FX50 rotors?
Yes, i know but i have my 18" wheels for the winter and i am 100% sure that they will not fit. And i don't want to sell those wheels because of the brakes...
If it's a matter of spacers i don't mind. Maybe someone else can confirm this.I recall a member on here from Alaska/Canada that put 18s on his FX50.. it made the brakes look huge, but it fit... I wanna say he didn't use spacers, but not sure..
18" OEM wheels won't clear, you need around 15mm spacers, but don't quote me on that.
you can check clearance here:
http://www.conceptzperformance.com/images/czp/barge/czpg37frontbrakeoutline.pdf
I checked out your 18's Ian, there was only a few mm clearance with your OEM calipers (non akebono bbk).
for the gen1, it also requires more parts for the REARS such as the rear knuckles and turbocad6's balljoint adapter. fronts are direct bolt-on.
great deal if it all comes together. i'm still please with my akebono setup and stopping power is a huge improvement (thanking turbocad personally for the gen1 research/testing). :smile (2):
Hey guys...how hard is it it retro fit the rears? Worth doing...any issues aside from the
extra parts? Can you get these from turbocad? Seems like a great deal for all four corners
