Awwwww yeah. It's time to lock down the parts and the kit. Been blogging a bit about my learning experience - pretty much talking to all the other forums out there representing the other VQ35DE communities. I've learned that I'm going to be doing this in steps. My goals for this install are on the conservative side, with an eye for future expansion. I want to keep costs down and plan to keep all stock engine internals in place, with no need to pull the engine for the boost install.
First step will be to install the turbo kit on the stock engine internals. I'll be upgrading the fuel delivery (pump & injectors) and installing a TT kit with a new EMU. My goals will be for 7-9 psi boost at 375 whp. Community experience says there are plenty of VQs out there running on stock internals up to 420 whp. Some have bent rods under this whp, but with a good tuning, I believe this risk is small.
I'll be looking to size the turbos so I can have some forward expansion when I build the engine in the future. We're probably talking a year or more after I install the turbo kit initially, but it will include pistons, rods, cams, valve springs, fuel rail & bigger injectors.
The EMU I go with will be whatever my install shop is skilled at tuning. I'll make sure the EMU will take me from the intial install through the future expansion so I don't have to re-buy that component.
The JWT TT kits are a possibility 500bb or 700bb kits - but I can only consider these only if the local shops that I talk to are certified to install it. If not, then a Greddy TT is probably going to be the way I go. I'll begin by looking at a pair of 18g or maybe 20g turbos.
