Install New Shocks, Struts and H&R Springs
MTN FX
Mountain Man
Premium
Big Bear City,Ca.
2004 FX35 AWD
John Green
Front Struts & Springs Replacement--
1) Raise vehicle onto jack stands remove wheels--
2)Remove retaining clips for brake line,abs sensor,e brake cable(rear only)
3)Remove Sway bar link from strut--
4)Remove brake caliper and tie up out of way to support brake hose.--
5)Support wheel assy with floor jack--
6)Remove two lower strut mount pinch bolts and tie hub assy in place--
7)Remove top three strut nuts and pull strut out.--
8) Use spring compressor to compress spring--
9)Remove nut on top of strut--
10)Decompress spring compressor and disassemble strut--
11)Replace upper strut bearing--
12)Put new spring on strut and compress with spring compressor reasemble makining sure that spring is positioned in seat pocket then put upper strut bearing assy back and replace nut on strut piston rod end and tourqe to 58 ft.lbs.--
13)Guide strut assy up through three mounting holes in wheel well and torque to 35 ft lbs.--
14)Re attach lower strut mount bolts and torque to 134 ft lbs then re attach sway bar link to strut and torqe to 75 ft lbs.--
18.jpg\
Re attach all clips for hose,wire etc.. Done with front install.
Rear replacement of shocks and springs--
1)Support spring can with floor jack--
2)Remove upper and lower shock mount nuts and bolt then remove the shock--
3)Remove bumper and gator and put on new shock--
4)Put new shock assy back and torque upper two mounting nuts to 22 ft lbs and lower mounting bolt to 66 ft lbs.--
5)Pull spring carrier bucket bolt and lower jack and remove spring--
6)Instal new spring and then place jack under spring carrier bucket and jack up to install bolt.Torque bolt to 77 ft lbs--
Done with install--
:tup::tup:
Making it look easy...:biggrin:
Thanks for the write-up, this should definitely help our members out....
It was allot easier than I thought it would be the whole install only took 2 1/2 hrs.
And the fact that the FX's have no adjustments other than toe in makes it a breeze.
wow awesome write up man! you just inspired me to do this over winter break
one question though, you said that we only have to adjust toe on the fx. how do we do that after installing springs?
great write hopefully this will encourage the other guys on the forum to tackle this project on there own because it is not difficult at all. considering what shops will charge for this.
Just would like to add in case anybody is planning on tackling this... please do not disassemble the strut assembly without a spring compressor.
how does it ride? better or the same?
I'd say about 30% better in ride smoothness and handling.
It's like a new ride:tup::tup:
---------- Post added at 06:46 PM ---------- Previous post was at 06:44 PM ----------
Wait about a week for the springs to settle then take it in for a four wheel allignment
---------- Post added at 06:47 PM ---------- Previous post was at 06:46 PM ----------
I hear that one shop up here quoated me 800.00:tdown:
---------- Post added at 06:49 PM ---------- Previous post was at 06:47 PM ----------
having that spring compression tool is key - did you have that or the guy that brought the on-wheel rotor lathe?
My buddy's spring compressor.
yeah, adding to what jeff has said, the spring is under a lot of tension & can really hurt or even kill under the wrong circumstances, if your not comfortable with & have the correct tools to safely compress the spring then don't go hurting yourself either to save a few hundred bucks... if you try to remove the center strut nut without anything holding back the stored energy of the spring then it can & will release with enough force to def do damage...
nice. im close to pulling the trigger on a set of eibachs. but not looking forward to the price of install.
If you drive to Baldwin Park to Street Image, labor is only $120 and they do quality work.
Nice write up John. when are you going to post pics of your FX lowered?
