Speedometer cluster
///5380&highlight=cluster
and a pic from turbocad
Also remember, messing with your cluster will void any and all warranties you have on your vehicle.
Wow I was actually thinking of doing this too. Saw a cluster for $600, thing is... I wont be able to do it myself and I can only imagin who really knows how to do it, and how much they'll charge. Good luck.
Anyone know what would happen if you plugged an 03-05 cluster after you added the extra power wire?
Speedo seems to have failed so want to plug in my 03 cluster back in to see if it's the cluster or a speed sensor.
most likely the trace is just open in the original cluster & it would be fine to just plug it in, but to be 100% sure you'd have to check the circuit board or at least cut that wire or remove the terminal for now, better safe than sorry :)
Convinced me to now just plug it in and try it, don't want to ruin a $900 MSRP OEM piece:)
Dang cluster why did you fail on me!:)
Will be sad going to the OEM 03 one, it will be so dark.
So just the speedo part stopped working only? I feel partly responsible for this.... :balanced:
You are definitely not responsible. It just failed on its own. Was working until now. No big deal will put in old one.
Yeah just the mph/speedo doesn't work. Rest is perfect.
I did a search and some nissan clusters have failed, and just the speedo.
You can by OSB2 bluetooth reader from dealextreme, and get Torque for android phones works perfect with samsung galaxy S. Then you get a great speedo and more in the phone display, and if you add another app you can get the speedo in the front window, like on screen.
I use this one and it works great in my infinti fx50 2009.
ELM327 Bluetooth ODB-II Transceiver dongle.
Manufacturer's product description:
bluetooth ELM327 is the newly developed wireless scan tool. It supports all OBD-II protocols
• Works with all OBD-II compliant vehicles
• Wireless (Bluetooth)
• Software included for Palm, PDA
• Software included for Windows PC
• Software included for Windows Smartphone
• Supports ISO 9141, KWP2000
• Supports SAE J1850
• Supports CAN bus
Functions:
• Read diagnostic trouble codes, both generic and manufacturer-specific, and display their meaning (over 3000 generic code definitions in the database).
• Clear trouble codes and turn off the MIL ("Check Engine" light)
• Display current sensor data, including:
• Engine RPM
• Calculated Load Value
• Coolant Temperature
• Fuel System Status
• Vehicle Speed
• Short Term Fuel Trim
• Long Term Fuel Trim
• Intake Manifold Pressure
• Timing Advance
• Intake Air Temperature
• Air Flow Rate
• Absolute Throttle Position
• Oxygen sensor voltages/associated short term fuel trims
• Fuel System status
• Fuel Pressure
• Many others...
Website for torque: torque-bhp.com
Interesting will check it out.
So after a few hours of driving, bam speedo works!
Who knows. I'm happy:)
