Custom CF interior
theMerchant
iS VIP
iS VIP
Found this over at g35driver...
Check out these custom wrap carbon fiber interior trim for FX.
http://g35driver.com/forums/media-s...-carbon-fiber-interior-trims.html#post3711984
no details yet, but look pretty nice.
I wonder if it comes in different colors/patterns
i wouldnt mind having the bottom half console part that goes upto the clock but thats about it...too bad this wont work on my FX, looks like 03-05 only
I think the difference between the "CF wrap" compared to the ones others have posted is the fit and finish. most dash kits are precut and leave an undesirable transition between the stock part to the kit. (almost like a seam)
I think it depends a lot on the installer. I have seen the kit I posted with pictures, could not find it again, but its looks perfect, but then again if you get an amateur to install it, who knows what the workmanship might be...lol. Either way I would have to see it in person, close up. I like all of the sites posted, but then again I would have to see it in person, close up.
+1. Molded kits are the whole piece if I recall. But I don't see many molded kits out there due to cost most likely. All the kits are typically the ones you lay on top.
Something about this kit just doesn't work for me. Almost like CF overload. I think the piece around the shifter bothers me the most. It's like it just doesn't flow or something.
I was / am thinking about some CF things as well. If you do it right CF can be very cool. But when done wrong it's often overkill.
Jason, you seem to work at burtmann...?? Can't seem to find those mirrorcaps on the burtman website. Merchant any ideas who would have made these and/or were it can be done or bought.
If it is for sale i rather buy it then let it be made as it is often a better quality when made in production.
Futher the mid comsole in my opnion would need to stay aluminium, but around the door grips and airvents i am decideless on going for CF or alu as all silver alu is also a bit to much silver in my opnion. CF is black and you sometims need to look twice to see it. Silver is all in your face.
So like the OEM alu don't get me wrong but don't want any overkill of what soever.
I'm the owner :) See more installed pics here.
http://www.burtmanindustries.com/zoomprod.php?id=FX35-45_real_gb_car
Yes, I agree, sometimes less is more. You don't have to install the shifter plate piece. Sometimes it looks good left alum.
Ohhh the owner. I emailed or called you a while ago then i gues. If it was possible to combine alu and carbon in a set. I'm still not sure what to do and have many other plans as well :laugh:
Do you have any idea on the mirror innercaps on the pic above...?? You don't offer them do you...??
