M
Mikefx3508
Guest
I was wondering about this, because I was having some fun with my FX one night coming home from plaza so i decided to floor it past another FX. I'm not sure if it is supposed to go to the red zone or not.
i drove home past weekend.. and i was wondering how is it that you being hitting 6k rpm so easily.. so i decide to see if i could managet o do the same.. i realized i only hit 4-5.. after that it keep going up easily.. so stop having a led foot!!!!![]()
Maybe it depends what year FX you have, what year is yours btw? mines an 08
redline is after 6 1/2. I think it will not harm the engine as long as you don't hit the redline.redline its at 7rpm right?? so it wouldnt damage anything if one floor it to 6-61/2?
there is no upshift but there is rev limiter.In the manual mode there is no upshift override so you can bounce it off the redline all you want.
Maybe at 6750 .. the best way to figure it out is to try it. Drive it pass to the redline. Try to shift at 6750 if it hit the rev limiter try again to shift a little before it.At what RPM does the rev limiter kick in?
I used to shift before at 6000, 6250 ! after that I tried and find out that I can take it till 6500 in first and 6750 in second and third gear without hiting the rev limiter.
:err:! maybe my ECU acts different ! I live in middle east maybe we have different features than the american ones. For example, All FX35 comes with standard packages and the temperature is always at 1/4. Also my FX Autoshifts from 4th gear to 5th at certain RPM.I just took it out for a drive and had it up to 7700 rpm with no sign of a limiter...
But I know it's higher than 7700 rpm.
This video explains my rev limiter?
