Interior Rebuild Thread
Butane
2015 Q50 2010 G37 2014 QX70
Jer
Hi!
Welcome to my current project hopefully you find some information on here useful. I purchased a 2014 Qx70 with 200k on the dash. It wasnt in the best of shape so this thread will be my rebuild journey. I will organize this with the pictures and steps I took at a later date.
Notes;
Wiring harness and some interior trim pieces were swapped out. Rear door wiring harnesses are harder to remove as there is not panel for access like the front doors. Center console does not have a 10mm bolt under the windshield to worry about. Take photos of connectors and what they are connected to. The airbag module underneath the center console is different depending on the year so be careful, even swapping the harness out the other harness attached to the front of the vehicle and center console area are all one big separate piece from what runs through the car and its srs connector is different. Radio has a lot of connectors so pay attention to how they go. Previous experience tells me that whenever removing rear bumper always put all connectors back in place, these bumpers love to fly off. Be extremely careful removing tail lights, the material used sucks and they will snap at the pull points where your supposed to pull from. Be careful when removing steering wheel that the clock spring doesnt open up. Be careful that you dont pull out the start button when removing dash. The Dash material is very sensitive so mind where you place it.
I did not forget about this, I have been running into small issues here and there. In hindsight I should be documenting as I go along so I will do so below. I have a lot of photos and videos so I may save all of the photos until the end of my write up or implement it with the relevant sections. Lets see.
This thread will be relevant for anyone that needs to take apart their Gen 2 fx or qx70. Everything on the interior got ripped out and put back together so I know a thing or two.
First things first, Why I am doing a all of this work? The Vehicle I decided to go for had a lot of problems I was not initially aware of but I was willing to fix. I gave myself 2 weeks to tackle it and I am making good progress.
Problems;
  1. The wiring harness starting from the driver side fusebox and running the entirety of the vehicle to the passenger side had some chewed wires. Specifically in the rear of the vehicle where the harness connected to the amp there was chewed cables etc.
  2. The music sounded extremely quiet and terrible so needed to diagnose that.
  3. One of the windows would not work.
  4. The radio screen would intermittently cut out and reset.
  5. The backup camera returned a non existent fuzzy feed.
  6. A/C system sounded extremely loud.
  7. Wobble/noise in one wheel.
  8. Ebrake got burned by prev owner as I was following them to sign papers.
I think that’s everything, besides how dirty etc it was, Ill leave out most of the cleaning and extra info and leave this mostly for the process.
So what I needed to do was get the electrical situation sorted out, test and replace electronics, add whatever I wanted to add, put everything back together, get suspension problems fixed, work on any mechanical issues.
In hindsight the harness wasnt that bad and probably could have been repaired but with electrical stuff I didnt want to take a chance.
Due to the dirty condition of the vehicle I also wanted a chance to clean everything and get rid of any mold etc.
First trip was 2 hours home where the vehicle performed to the best of its abilities, It had a cel for the MAF sensor but the seller lmk that ahead of time so I came with a new one. The next trip was to the diy car wash where I spent 3 days removing trim and vacuuming / washing ALL of the cracks and crevices. I plastic bagged any connectors and fuse boxes etc and went to town cleaning.
After the cleaning came the checklist of what needed to be replaced. I concluded that at minimum I needed a new Amp, Airbag modules, wiring harness, carpet, speakers, weather seals, seats, and steering wheel.
I also decided to add multiple layers of sound proofing while I was in there.
Next trip was to the junkyard where I spent 2 days completely stripping a gen2 fx35. I grabbed the wire harness, modules, and weather seals on day 1. Day 2 I grabbed the infotainment, speakers, and trim as well as some extra trim pieces in case things were broken or too dirty.
Dismantling the Q;
The next day I proceeded to strip the Qx70. I started with the seats as it was the hardest thing to remove at the junkyard and would free up a bunch of room. Seats are easy just move the seat back and forth to expose the 2 bolts in the front and 2 in the back. Then disconnect harness and your good to go. The rear seats have pull tabs on the bottom and then the backrest requires dismantling the trunk roof speaker trim and the seat belts. Take photos of how things are situated. The seats line up but the seatbelts etc may get confusing. Also I believe the seats have a order, the bigger passenger side one has to come out before the single driver side back does.
Once the seats are out then its time for the center console trim.
This is pretty straight forward if you take your time to look for screws. Start at the back with the ac vent and work your way up. Make sure your ebrake is on when removing the shift knob. Also leave the metal gate at the rear of the center console and the yellow srs airbag module under it.
Once the center console is out you can head towards the pillar trims, headliner and trunk trim. The dashboard area I would save for last on a fresh day.
Removing Dash;
Not necessary for carpet replacement, wire harness replacement, or sound deadening.
To start with the dash I recommend going at the glovebox etc first since its the easiest to take out. After that start hitting the side panels of the dash where they meet the door. After that go for the trim that has your trunk release etc then steering wheel column. Itll be easy if you unscrew the locking bolt in the middle of the steering wheel but DO NOT unscrew it all the way it will save you a lot of time from putting it back together. Next go to the top where the ac vents pinched against the windshield are and remove the clips from in there. I believe the odometer also had to come out so slowly work out the trim surrounding it which should be easy after disassembling steering column.
Next look for any remaining connected wires. Specifically for the push to start and the tweeters on both corners of the dash. Lastly the steering wheel may need to come out. Grab a sharpie and mark the orientation its in on a visible but inconspicuous area, also mark the clockspring etc to make lining up easier. Grab tape and when you careful disconnect the steering wheel from the clock spring tape it in its exact orientation dont spin it. Next make a nice clean area to put the dash, its kinda heavy and the soft trim material is prone to scratches and punctures very easily.
Once thats all said and done you should be ready to pull out the dash!
Wiring;
Disconnect the battery safely!!
Do this WITH the replacement harness so as you disconnect you reconnect immediately!!
Obviously do not feed the harness through holes if you havent pulled the original harness out yet to avoid breakage
By your feet where the fusebox is you will see a thick harness of cables. Make sure you only unplug the connectors associated with the wiring harness. There is a cool clamp lock that you flip down and that releases the main harness. Unscrew the ground bolt and then slowly start pulling the harness up. Your going to see one cable leading to the center column towards the passenger side, thats for the kickplate light so just disconnect it or cut it if your brave and can quickly wire it back. You also have the off shoot for the drivers seat and srs yellow connector for the center console module.
Next your going to run into the seatbelt srs airbag cables. As long as your battery is disconnected your safe to remove. Slowly pull out the black internal connector and then you should be able to pull it loose. Then unplug the other 2 connectors.
Next where the back seats are you will see the harness lead in two directions, one towards the trunk and the other towards two circular cutouts by the seats. If you twist open those lids you will see regular connectors you can unclip. Take photos of all the mounting spots where the cables are clipped onto for organizing later. Its very important.
Once thats done you move to the trunk area walls. The harness splits here again. One way towards the headliner and the other towards the floor of the trunk. The headliner is a quick few connectors and another srs connector and maybe a ground bolt. Dont try to pull out the roof connectors its unecessary just disconnect when possible.
The trunk has your tail lights, different harnesses leading to underneath the vehicle, and harnesses going to the amp and srs module. Be very careful removing the tail lights. Everything comes out as one piece and is again pretty straight forward so just dont yank anything and make sure you got every single connector. The bumper needs to get removed for the sensor cable unless you have room underneath the vehicle to do so upside down as its easily accessed like that as well. Towards the middle of the trunk on the underside there are two connectors in a difficult to reach area that are also tied to a cable that has nothing to do with the harness. Cut the tie tying these two cables together and disconnect the connectors so you can pull them out. Same thing for the other two connectors located to the right corner underneath the vehicle.
Once your back inside proceed to disconnecting a few more connectors and head back to the cabin. This is the same as the other side and once you reach the glovebox area you have another one of those cool clamps to connect the main
harness.
Removing Floor;
With all of the previous work done this is going to be the easy part. Just slowly start pulling up all of the carpet. The carpet around the center console you may need to cut in a few spots but besides that it should all come out in one solid piece. The only confusing part is the rug behind the gas pedal. The gas pedal has a secret compartment in the front base that you pry up to reveal two bolts. Be careful unscrewing those bolts as one of mine sheered off.
Sound Proofing;
This is a question that gets asked a lot and honestly it depends on the person. Some people will say theres not a noticeable difference while others will say that its like night and day with the sound deadening. After doing some research sound deadening really only works if applied correctly and in layers. Yes you can go ahead and just do kilmat and be done with it but if your already in the car doing all of this work you might as well take advantage and do the job the right way. With that being said just using kilmat is not the full job, the other materials you can add is CCF or closed cell foam, MLV mass loaded vinyl and decoupler layers such as acoustic foam. The recommended order is the kilmat (butyl), CCF (acts as decoupler or dead space), and then MLV. There are better alternatives for butyl with better stats such as amazons very own in house ones but I used kilmat before so I went with them. After layering it through out the vehicle I put a layer of CCF down, then I realized that I may be doing a ton of work for something that I dont have running yet so I abandoned the rest of the deadening until a later date. Instead I opted to add a few mat cut outs and a water proof tarp as the final layer before the oem carpet.
Putting the floor in;
Before layering down the rest of the material, right after the kilmat I put down the foam inserts that are located in the deep pit areas in front of and behind the front seats. These foam foot inserts are needed as the carpet will just cave in so be careful removing them and make sure to put them back. Once I put all of that in I added the CCF and water proof tarp. The water proof tarp is for those pits I mentioned earlier, they do not have drain ports and thus hold water/moisture indefinitely. There was a swamp in mine, and in the fx I stripped there was a small puddle even though it had not rained in weeks and had been sitting in the lot for over a month. So to mitigate issues with future spills I decided to go ahead and just add the tarp so that it holds the moisture on the carpet layer for easy clean up.
Things I encountered;
the Harness even though different models still connected perfectly everywhere. I did not encounter a unknown connector.
The seat harnesses have a extra cable leading towards the center console. Its yellow and it plugs into the srs module underneath the rear of the center console where the a/c vents for the rear are and the metal arch which I left on.
These connectors did vary by model so swapping harnesses is not entirely possible safely so do this at your own risk. The reason for this is that separate from the dash, the inner workings of the dashboard has a bunch of harnesses interwoven with the frame. I would never attempt to remove this as it looks complicated. Those cables connect to the shift assembly and center console ports. They also connect to the srs module so you either leave your old srs module and connect just the one srs cable or you install the new one and connect the two from the harness. I went with option B, the more airbags the better lol.
Besides that I did not have any other issues with any connectors.
On to the speakers. So the issue I mentioned earlier about bad sound and quiet volume was due to...... none of the doors having speakers
So went ahead and started going door by door to replace the wiring harness and/or speakers. The two front doors are simple, you unscrew the window glass, slide out the window from the top. Then remove the bolts outlining the panel so you can pull it out. Be sure not to unbolt the actual window rails.
With that just follow along the wire harness for the door and as you remove connectors connect the new ones.
The rear doors is a little trickier as their is no removable panel. I did not swap the wiring harness on these instead I saw that the previous owner spliced in two cables into the harness so I went ahead and wired those to the new speakers.
With that I was done with the bulk of the work.
Now I had to clean up any on going issues. I currently had fixed the wiring harness situation, fixed the music situation, and fixed the window situation as well as the Radio screen. What was left was to test the A/C and Backup camera. As well as fix the new problems.
New problems;
My gauge cluster turns on but none of the gauges move. I did some digging online and some people said that accidentally swapping two of the connectors for the radio unit can cause issues. Dont test it out! I tried it and immediately something started burning but thankfully nothing seems to be damaged.
So need to diagnose my gauge cluster, the next issue is the eject button doesnt work on the radio, the A/C unit wont come on, and some sort of parasitic drain is going on as my battery keeps dying. Next I accidentally broke the clock spring for the steering wheel, and lastly I need to replace two seats.
My current order of work will be the clockspring/steering wheel. Then Ill move on to the Gauge cluster fix by possibly just swapping it for a new one. After that Ill check to see if everything works. Will update soon. Also let me know if I should include photos at the end as well?
Went ahead and compressed the photos to upload, not sure if it’s because im using web browser via my phone but its saying my images are too big. If needed I can probably put all of the photos in a zip or upload via a host site like imgur.
B10743AE-42A6-4BEC-87BC-CB3E7DF385CF.jpeg C8EB7FCE-3212-49F5-B957-5D2377B6E201.jpeg 0724471C-574B-43EE-B79B-933650D26071.jpeg C0D714A8-6566-428E-96E3-2E9A365B4EFB.jpeg 3C0EDE31-78F7-4060-9344-1B32A2CBA82B.jpeg 108A73BC-128A-45E0-90F0-909B62B25989.jpeg C134BA8E-FF7D-44AE-ABF4-EC612FD9A705.jpeg 64935B96-5DD5-4904-8C4F-5D8FC4FBF966.jpeg 80B823DD-C0FB-4D4F-B0FD-A6B12D88CA6D.jpeg 49A88250-A152-4F43-9B61-F6C0648478AB.jpeg
New issue updates;
Headed to grab new parts today. I swapped the blower unit from my G to the Q and the A/C still did not come on so must be either a fuse, I blew the electronics on the infotainment when I did the swap earlier, or the connector itself is bad. The only things left at the yard are the speedometer, steering wheel, clock spring, and some foam inserts I forgot to grab. The infotainment box I may have to grab from a G if there is any at the lot. Hopefully this trip leaves me with the only issue of the A/C blower unit. I may try to grab the fuse boxes as a whole in case they are bad.
Update 2;
Went to the Junkyard and grabbed the ipdm (engine bay fusebox) the Fusebox by the passenger side floor, and some misc items. Swapping the ipdm did not fix my issues. Swapping the passenger side floor fusebox caused the vehicle to not recognize my key as I believe it contains the previous vehicle that I took it from security ID. So right now im stuck.
Wow man, you have balls to take all that apart. Too bad you are having all kind of issues. But good job on everything. I was going to do some mods, but my vehicle is giving me some issues as well and I don't really want to spend anything on it knowing that it may not last long.
The scary part is starting out lol, for the most part its easy, Iv done this and more to my previous cars with little to no problem. Its just since this vehicle had previous issues then theres always the added risk of encountering more. What problems have you been having? These VQ's are hard to kill and admittedly with the wiring bs im going through right now the engine is still running and its driveable lol.
Update 3;
I resolved the issue!!!!
Basically long story short I made a check list of possible issues that stretched out pretty far. I then ordered the list by cheapest and easiest to do. Working my way up the first thing I tried thankfully solved the issue. Earlier I mentioned I found on a obscure post in the g37 forum that two people were experiencing my issue and piggybacked off of someone elses post about a different issue. Thankfully reading through and seeing their comments I decided to look further into the topic of that specific thread and took a second look. In the thread its stated that there is a connector for the A/C Amp (white box attached to radio box) that can be swapped. It turns out that BOTH of the connectors for the A/C amp are swappable with the radio. That being said once I changed the other connector everything started working fine!
However the fitment on the dash is not perfect now as I mixed up some of the screws etc. in the future I will document every screw and were it belongs to make reassembly a breeze and fitment better but at this point Im just trying to get the vehicle up and running.
Currently the only things left are;
Passenger Seat - Need to Buy
Rear passenger seat - Need to Buy
Headliner - debating on painting or wrapping.
Oil change.
Wheel/axle issue.
Error codes.
Check all lights and everything works.
Photos;
I realize my documentation with the photos wasnt the best. I mainly took videos and remembered to occasionally take photos. I will look to see if any of the videos show important steps I havent posted yet. Specifically I would like to show the layering of the carpet. If not then eventually when I decide to go all out on the sound deadening and add more material I will be sure to take photos to post here. So far there is kilmat on all the doors and floor of the vehicle. I added CCF on top of the kilmat in some areas of the seats. Then a water proof plastic tarp was added on top (for spills) and then the carpet was added. If I didnt care about weight and money I would have added MLV and Foam layers below the tarp as one final measure. The easiest thing Ill probably do next if the sound deadening isnt up to par would be filling all of the doors with sound foam.
Update 4; Seat swap
Today im going to see if the seats from my G37 fit in the passenger side of the qx. If they do then I have a easier trip to the junkyard in order to grab 1 seat. If not then im going to have to spend a little more for a FX seat as they are rare at the junkyards near me. With that being said Im thinking that FX/QX/G/Q seats might all be interchangeable depending if they are the same gen year? The qx seats look different but might be the same harness etc. Ill try with the G and if it works im moving on to check out a qx56. If that works then Ill opt for that. It may be a bit of a eye sore being a different seat but its just till I find a part out with the sport seats or get fed up enough to buy new oem seats and get them upholstered.
Notes;
Some Harnesses/Connectors will have their opposites taped off but attached. For example a Male end connector will have the female end that it can plug into just wrapped up part of the same harness. Iv seen that for the lower half of the radio were the clock is located there is a connector that you can plug into the harness from the vehicle thats hidden away or use the male end of the connector from the vehicle harness and plug it into the clock.
Theres a few more that Iv seen around such as by where the hood release is. I also noticed that there is about 2 or 3 connectors in total that did not plug into anything either by the glovebox or by the keyfob trim area
Oh you know, same bs almost all QX's have, 7 different check engine codes related to TB (and not only), vehicle goes into limp mode, doesn't start sometimes, oil on spark plug.
Ah, Yea I havent encountered issues with the Tb on any of my VQ's but ik their finnicky. Iv removed them and cleaned them reinstalled etc same thing with the maf sensors and havent had issues. If you havent done sk Id start there as their pretty easy to work on just dont drop them or bang them around. The limp mode etc haven't experienced either. The 3 biggest issues im not looking forward to is the gallery gasket, the water pump, and the valve body. Everything else Im okay with doing.
