Side fender turn signal. The LED strip with the homemade brackets are mounted onto the back of the vent in the photo for test fit only. When installing, you need to remove them off the vent. Install the vent back onto the fender, so vent would flush the fender as before and then screw the LED with the brackets onto the back side of the vent through the wheel well on the inside of the fender.
H&R Spring & Megan Camber Control Arm Installation. The front spring and camber arm installation is pretty straight forward. The rear is way more complicated as you have to remove many more parts.
Installed my own DTRL with a set of 6" LED lights. I tap into the positive wire at the cigarette lighter feed a relay to trigger the auto turn on of the lights when the car is running. I install a second relay to turn off the lights when the headlight is on at night. I also mounted a homemade bracket using some aluminum angle strip to mount the LED onto. In order to mount the bracket to the frame, the bumper cover need to be removed. Here are some photos of the installation.
