WRP Technology
  • Thread starter Thread starter Psiclne
  • Start date Start date
P
Psiclne
Guest
Look what I got in the Mail today - Gonna head out to LMS for the install now.
Its 5lbs lighter than stock - so we'll see how it works out.......I'll report back in a bit.:iS:
Just got back -
RPM's seem to climb with more ease.....No noticeable power increase with the butt dyno. Will test out some more over the weekend. Sure looks pretty though - hahaha!
Looks good. i felt my gains off the bat with mine, but they did an ECU reset for me (pedal method). give it a restart and after a day you might feel something. some reports on the org say it took a while for the ECU to adjust for their crank pulley.
i love mine, but im getting some squeaking from the belt (i guess during the winter the belts contract because of the cold) ill have to have the belt adjusted a bit.
Pics?
How come the butt never feels anything???
Cuz theres a sign on mine that says "Exit only - Do not enter" :laugh:
I'll see about a reset - the rpms do climb with much more ease - so thats a good thing.
Looks good. i felt my gains off the bat with mine, but they did an ECU reset for me (pedal method). give it a restart and after a day you might feel something. some reports on the org say it took a while for the ECU to adjust for their crank pulley. quote]
A bit off topic, but is there a difference between the pedal method to discontecting the Neg on the battery?
When you do the pedal method its a lot quicker then disconnecting the battery. also it only resets the ECU learning so you dont lose your radio presets and things like that.
i try and do a reset every month or so...
looks good, even sleeved... way better than the cnr pulleys we had couple years back, had to take mine off and on 3 times... I am pretty sure the owner of WRP is on our board.
yeah I told him to come over and check out IS - might get more bites over here. The thread over at the Org wasnt moving....did he sign up Jeff?
Yes, but will not show up on the members list because there is a 5 post minimum.
Looks good, I may look into that down the road if nobody reports any problems with it. I'm still a fan of the stock pulley ever since all the research I did into crank pulleys due to the CNR issues.
I don't think you'd feel much in the butt-dyno from removing 5 lbs of rotating mass. You drop 2 lbs of weight on each wheel and you'll free up a lot more rotating mass than 5 lbs of pulley... but you may see free-revving in park go up much faster because the rotating mass doesn't involve the full drivetrain this time and 5 lbs is a healthy chunk in comparison to THIS amount of rotating mass.
I mean I didn't feel a whole lot when I did all 3 CNR pulleys, except when I would rev in neutral or park.
hey thats awesome! i was just crusing google and ran across this thread!
well some time has passed, how happy are you with the component? I hope you are!
let me know - i will be more then happy to set up a gorup buy for the forum if i'm allowed to :)
