FX35 VDC off?
Discussion in 'FX (03-08) - Engine & Drivetrain' started by imballin2day, Jan 6, 2008.
  1. imballin2day
    imballin2day Member
    151
    LA
    Last night I was driving in the rain when I made a turn. The VDC, Slip, and service engine soon lights all turned on at the same time. Then as soon as that happened the car would not move when I pressed the gas. I turned the car off let it rest and it worked. As the night went on it kept on happening and getting worst. The car would stop moving in the middle of busy streets. Does anyone know whats wrong?
  2. brown_fv
    Could be a number of problems with the VDC, slip & check engine light on. but your car stalling on the road; maybe you have an issue with your throttle body and dirt in your MAF has caused your car to go into limp mode...im not sure.
  3. Dr.2K
    11,683
    9
    Santa Clarita, CA
    2005 FX45
    Check the ecu unit as water could have gotten to it thru the firewall.
  4. Emkwan
    Emkwan Member
    11
    Abu Dhabi
    Emkwan
    I've just started to experience this. Took to dealer... They have no clue. Frustrating.
  5. mishanja
    mishanja Member
    1,175
    9
    Sugar Land, TX
    2013 BMW X5
    Does it throw any codes?
  6. g0ldm4g3
    g0ldm4g3 Would ya just look at it iS VIP
    5,636
    129
    Richmond, TX
    2006 FX35 RWD
    Nnaji
    Just pull the code..
    Sent from my SGH-M919
  7. FX Brad
    FX Brad Member
    2
    Canada
    2004 FOR AWD
    Brad
    Min did this exact issue last month turned out to be CAM SHAFT POSITION SENSOR, Right bank. Stealership replaced no issues since.
