Stock Bose Subwoofer
Discussion in 'FX (03-08) - Electronics & Lighting' started by MASSIVE, Mar 11, 2008.
  1. MASSIVE
    MASSIVE Member
    188
    Maryland
    I know alot of you on the forum are running aftermarket systems and speakers in your rides. Unfortunetly I haven't been able to start that, but time is on my side. I've noticed that my stock sub cuts on and off depending on alot of things. It sometimes cuts on and off if I hit a bump or pretty much when ever it feels like it. I wanted to know if this was something that has happened to any of you or is it a sign that it time for the upgrade. I know Deecarp had a problem with his stock sub before he did the upgrade, but his problem had to do more with the thump then anything else, off course now he doesn't have that problem anymore (nice work with the car DC).
    Any input on this would be greatly appreciated.
    :confused:
  2. Keemo
    Keemo Premium Member Premium
    1,108
    Edmonton,AB
    I actually have noticed that the bass will kick in and out sometimes.
    It's really noticable when i first fire her up and have the system on, seems like it take a few seconds, like 5-15, for it to start making noise, uh, I mean music. :confused: Interesting.
  3. john
    john Member
    55
    Wisconsin
    I find the stock 'subwoofer' a great underperformer, and can't wait to replace it with a jl 10w2.
  4. livinpimplife
    livinpimplife Member
    151
    SoCal
    i have this exact problem. i think after u have the car for 3 years or mayb a lil less this happens.
  5. brown_fv
    1,703
    Toronto, On
    Just junk it and get a nice set up!
  6. jbaker1121
    8,938
    125
    Westchester, New York
    Car:
    09 FX50
    is that the uber thin one?
    thats the one i'm waiting for :)
  7. robb<35>
    robb<35> Member
    710
    maple, ont
    looks like a good set up , and stock bose is alright but nothing special
  8. OP
    MASSIVE
    MASSIVE Member
    188
    Maryland
    Now for those of you that still have the Stock Bose Setup, do you have the Speed Sensetive Volume turn on Low, Med, High, or OFF? I have mine turned off and i still have this problem. i use to have it on low but after i noticed the problem i turned it off to see if that was the issue, guess not. I guess it is time for the upgrade.
  9. Psiclne
    Psiclne Guest
    I have mine set on low - and have no issues (knocking on wood).
  10. Deecarp
    Deecarp Member
    1,479
    12
    Bay Area
    Car:
    QX60 AWD
    Name:
    Darryl
    Hey Mark, get the amp checked first. it may not be the sub cutting out but the amp. nice to know you are back out on the road. I'll holla back at you later on...
  11. john
    john Member
    55
    Wisconsin
    No - it's a generic dual voice coil 10" sub. I had it in my Audi, and was going to put it into my Subaru, but I think it'll serve the FX better. :)
  12. mayfx
    mayfx Member
    23
    Houston, TX
    Where is the amp? Are all the speakers hooked to the amp or just the sub?
  13. Keemo
    1,108
    Edmonton,AB
    I think, but am not positive, there is one in the dash for the speakers and one in the sub box in the spare well for the subs.
  14. mayfx
    mayfx Member
    23
    Houston, TX
    So is the amp adjustable? I was just thinking the other day how I wish I had a crossover. Is there a crossover on the amp? When I have the ipod hooked up through the radio, certain songs are supper bassy through the highs.
  15. Keemo
    1,108
    Edmonton,AB
    This is what the inside of the subbox looks like. I was hoping the same thing so I ripped into it finding that it is not adjustable. :frown: The amp is the tiny box looking thing next to the back 'sub'.
  16. mayfx
    mayfx Member
    23
    Houston, TX
    Thanks! Is there anyway to add a crossover to the system? Or should I just invest in a better FM modulator?
  17. OP
    MASSIVE
    MASSIVE Member
    188
    Maryland
    Does anyone know where the ground points are for the Sub or the Amp in the trunk? I think my problem is a bad ground point. i notice how it cuts on and off as i drive and depending on when i hit the brakes or turn a light on in my car the sub cut on and off. if i could look at the ground points and check them all it might solve my problem.
  18. theMerchant
    theMerchant iS VIP iS VIP
    5,177
    81
    Southern California
    its all ground, but to get a better ground, scrap some paint away where the point is.
    But your problem sounds like a "loose" fuse. I had similar problems with a fuse (in large clear fuse holder) that would barely make contact with the two ends. Sometimes its because the fuse holder isn't screwed all the way shut or the fuse is too small.
    Also see if you can replicate the problem when you are parked and shake some wires around.
  19. FXtion
    FXtion Member
    792
    sherman oaks, ca
    Look at the pic in the post by Keemo. The AMP is in the Sub cavity. Check the Connector going the Sub. There is a larger Black wire which is your ground and the Green wire is your power. What you can do is to Cut it about a Few inches back, extend the Wire about a few feet, and find a ground close by. There are a bunch of bolts behind the rear seats that you can use, or you can make your own connetion. Like TrainerKEN said, strip a little paint to bolt it down to the bare metal, then put some Vaseline on the bolt and the connection so it does not rust.
    Good luck
  20. nogovitsin
    nogovitsin Member
    2
    Houston TX
    Thanks for the tip!!
