canada FX35
Hi can someone explain me some benefit of SS brakes lines. I want to buy it but i want to see some comment about that. Thanks
do you need to really buy stoptech lines that are about 200 for the whole set. or would an ebay set that is 100 for the set work just fine?
like these
http://cgi.ebay.com/NISSAN-FX35-FX4...hash=item300294054805&_trksid=p3286.m63.l1177
any other suggestions on where to buy them?
SS lines need to be replaced more often than OE lines. There are stories where the ss lines popped off the caliper in extreme braking situations. The non flex of the lines built too much pressure at the caliper connection, and just popped off when slammed on the brakes!
Here is his complete story and opinion on SS lines:
http://www.nsxprime.com/wiki/Brake_Lines
there are a lot of different opinions out there, that is one of them...
if the lines are correct, they won't be pulled out of there connection, there should always be more than enough slack...
rubber brake lines are crimped just like ss lines, so yeah, aeroquipt fit racing lines will be stronger, but ss lines should be no weaker than oe rubber...
one benifit ss lines have over rubber is, the teflon does not deteriorate with age or brake fluid exposure, where rubber does.... most common problem with rubber lines is they deteriorate from the inside, they eventually swell up inside & restrict the fluid orifice... this can cause sticky calipers, delayed braking on one whel, uneven braking etc.. teflon ss lines don't have this issue, so really, even though that wiki says differently, the ss lines should last longer than the stock rubber lines....
I would be very leary about buying budget lines, I'd def stick with a well known company that has many thousands of these in service for many years, any issues stoptech may have had are sure to have been discovered & corrected by now, I'd hate to be in the first few batches of some small manufacturers run & then wind up with issues, brake lines are not something to cheap out on....
i've used SS brake lines in 4 of my cars and haven't had a single problem including the FX which i recently upgraded to the akebono kit. i don't track the car or anything, just like the solid feel SS brake lines give. good choice with the stoptech. don't want to cheap out on something like your brakes!
yeah, what would even make the mechanic think that? my guess is he doesn't have a clue... I've seen some who insist that you should turn the ac & the radio off before you shut your car off so it doesn't kill the battery too![]()
