SS Brake Lines?
Discussion in 'FX (03-08) - Wheels & Suspension' started by Psiclne, Aug 31, 2007.
  1. Psiclne
    Psiclne Guest
    Are there other companies besides Stoptech that make the SS lines for our cars? If I do get the lines would it make sense to get all 4? Anyone know of any deals?
  2. Dr.2K
    11,683
    9
    Santa Clarita, CA
    2005 FX45
    Yes, Will you may as well get all 4 while you are at it. I have seen other brands on ebay for the ss lines. Search around the web as I am sure there are others out there. But the stop tech works and fits fine and pretty cheap.
  3. OP
    Psiclne
    Psiclne Guest
    Is $170 shipped pretty good for a set of 4?
  4. Dr.2K
    11,683
    9
    Santa Clarita, CA
    2005 FX45
    Will, here's a link to mynismo.com for the stop tech ss brake lines http://mynismo.com/products/?id=3363
    You should pm Joe on the org and ask him what kind of price he can get you on these to.
  5. OP
    Psiclne
    Psiclne Guest
    A lil cheaper at mynismo.com $165.60 but thats before tax.
    Lemme see what Joe can do-
    Thanks Doc for the help.
  6. Dr.2K
    11,683
    9
    Santa Clarita, CA
    2005 FX45
    Anytime Will :)
  7. Chedman13
    Chedman13 iS VIP iS VIP
    9,168
    103
    Illinois
    http://www.nsxprime.com/wiki/Brake_Lines
    Some information on Stainless Steel Brake Lines. I'm being over cautious, but decided not on getting them after reading that website. Doesn't mean I won't get them in the future though, just not at the moment.
  8. Dr.2K
    11,683
    9
    Santa Clarita, CA
    2005 FX45
    That's informative but some of the comments seem to be on the extreme side.
  9. Dr.2K
    11,683
    9
    Santa Clarita, CA
    2005 FX45
  10. Chedman13
    9,168
    103
    Illinois
  11. Dr.2K
    11,683
    9
    Santa Clarita, CA
    2005 FX45
    I think so because we all did get the replacement part. So I would think stop tech have updated the part. I have had no problems with mine and I have already replaced the axis pads that came with the upgrade kit. I have oem pads on now.
  12. OP
    Psiclne
    Psiclne Guest
  13. OP
    Psiclne
    Psiclne Guest
    Joe quoted me $180 (special order).......so looks like I will get it from Ebay. Thanks everyone for the help.
  14. wiseguywm
    wiseguywm Member
    180
    Norristown PA
    brake fluid
    is it necessary to change your brake fluid to (motul) brake fluid? When these stainless brake line are advertised they recommend changing to a high proformance brake fluid.
  15. Chedman13
    9,168
    103
    Illinois
    No not necessary to use high performance brake fluid. When you change lines though you should change your fluid anyway. High performance fluid does not cost that much more and you do not need a lot of fluid to flush.
